Dark_horse
Thanks I appreciate the kind words... Hopefully my experience building one will help someone down the road as well...
You can use plastigauge, it's not quite as accurate but it will get you in the safe area. I would recommend getting a set of micrometers though, they aren't that expensive anymore and you can always use them if you mess around with cars.A question for you earl, What if someone doesn't have access to a lot of the precision tools used to measure the clearances?
How big of a pita is it to get out without dropping the tranny? Hood is off for the added room
i used a 2x4 and ran two tranny bolts through it to hold the tranny up after i pulled the engine. run it across the front of the bell housing and support it on the frame down in the empty engine bay. (i can take a pic tonight if that would help) and taking the fan/radiator off i feel is a lot better, lots more room for the 10 minutes it takes to remove it. i also removed my hood. its another thing that takes 5 min to remove and its completely out of the way.
Dont forget billet oil pump gears, didnt see them on the list.
