Decision On Cams
Newman
sumidicsayhuh?
Houston
Ordered the BBR stage 1's this afternoon .. Thanks for the help guys
cam101
Very good thread. I have been thinking about cams for my ride. How much of a gain would I get if I were to get the BBR stage 1 or Hot Rods with my current mods. M90 Blower, 2.49 Pulley, KB Boost a pump. I am currently at 435RWHP and 420torque. Thanks in advance.
Dillon Dollar
oklahoma
The BBR Stage 1 wil definitly make more power on a boosted application than a hot rod
ford20
White Plains,NY
You can also go with the the Comp 127055 or the 127 205 since they are a blower grind they should be better suited for boosted applications
Kadorja
FNG
Jax, FL
BBR Stage 2 cams VSR Specs
Gross Lift Intake- .492, Exhaust- .492
Advertised Duration Intake- 284°, Exhaust- 294°
RPM Range 2000-6500. 241/251 .050"
BBR Stage 1 cam NSR Specs
Gross Lift Intake- .480, Exhaust- .480
Advertised Duration Intake- 270, Exhaust- 276RPM Range 1500-6000.
FRPP Hot Rods Cam Specs
Duration at .050", intake 221, exhaust 240 ,
lobe separation 110 degrees
You can see the difference from the FRPP and our stage 1's.
While I'm not the greatest at cam information I don't get the above comparison.... Advertised duration vs duration @ .050" shouldn't be compared.
BBRs are advertised as:
227/233 .050" duration
.480/.480 lift
114 LSA
And FRPPs are:
221/240 .050"
.472/.472 lift
110 LSA
With that information you can really see the difference but from what you posted you really don't have any good info on either cam. You have your cams lift without any info on the FRPPs and advertised duration is anywhere the cam manufacturer desires... from what I've gathered its actually pretty bad not to advertise at the standard .050"
This is just my opinion and feel free not to agree with it I honestly don't think its a good way to advertise any information against another companies cams.
Kadorja
FNG
Jax, FL
Actually you mean wider LSA. The 110 is tighter and increases cylinder pressure N/A. So with a supercharger or turbo it would have more a higher boost reading but make the same power as a wider LSA cam making lower boost reading. The tighter LSA would run the risk of detonation before the wider LSA cam.
But honestly either way with the stock block you can get the same max power out of each cam eventually.
Dillon Dollar
oklahoma
Yes that's what I meant just got them mixed up and you do have a point for power being maxed out on stock block... But in the long haul I feel if your going to use boost get cams to match
cam101
Apprciate it Dillon. I know with Comp you lose some driveability. I think might have chosen my next mod for the roush. Thanks again.
SteveP
Modular Specialist
Boynton Beach, FL
^ I had the comp stage 2 blower cams in my car before the BBR stage 2's. I picked up 20ish rwhp with the Comp and almost 40 with the stage 2s. Plus the fact you can hear the cams now. You would have had no idea i had the comp cams. Wasn't impressed at all. (my own experience remember)
Also, was good talking to ya saturday. Enjoy the stage 1's.
JoshK
Modder AKA Fuel
Nebraska
Do you have any videos of your car with the stage 2s Steve? I would like to hear how they sound on a single turbo car.
