Sharad
Site Sponsor
Track guys, may 28th I think.
Cool! I'm planning to make this one as well. What run group do you think you'll be in?
Ill be in the beginner group
Actually talked to a local shop today and got a better deal on some BC coilovers. So probably going that route.
I was planning to just buy some stock rotors, fluid is already changed....what pads should I get?
Does this mean that Reybestos doesnt have a good pad for the rear? I'm leaning towards the ST43 on the front too.Hawk DTC-70 in the front and DTC-60 in the rear is used by a lot of people around here and they seem to like them.
Carbotech offers XP12/XP10.
I will be using the Raybestos ST43 pads in the front and Hawk HP Plus in the rear. Using Motul RBF600 and Ford Racing's brake ducts I had zero brake issues at Sebring last year.
Make sure to use new rotors for the new pads and do a proper bedding of the pads before you head out.
Well, that clears it up for me. Have you ever tried their more aggresive pads on the front, st41 and st47? How are the srt43 on rotors?No, it does not mean that, necessarily. Just sharing the combo I used last year.
When I bought the pads for the front, the ST43 compound was not available for the rears at the time. If they are available now, please let me know because I would love a set for the rears as well. I just haven't checked.
I used the HP+ in the rears because it was what I had available to me. It wa$ ju$t a timing i$$ue that ju$t $eem$ happen now and again
You will like the ST43 pads at the track. After the first lap or so of heavy braking (getting some heat into them), they will take all you want to throw at them. Keep in mind, once you're done with your track day, you will want to replace them back with your street pads and rotors ASAP for your daily driving. They are NOISY!!!!! and not very good at cold temps. I hope that helps.
For the price I'm surprised more people dont use these pads. Do you think ST43 front and rear on a brembo gt would work ok, or should I try a less aggressive compound for the rear. These will be a special order anyway. It looks like they do have the st43 rear available on special order.Nope. Just the 43's. And they are just as you would expect them to be on rotors. The rotors had some white discoloration from the heat, but no cracks or excessive wear. The pads will outlast the rotors if you need them to. I will just buy another set of cheap blank rotors when the time comes.
