Learning to make fast go fast!
05mustang_TT_charged
Because Race Car!!
LSU Country
I think you will be able to accomplish your goal pretty easily once you get comfortable with the car.
I went 10.3 @ 138 on the shake down passes with my car. It was making about 660rwhp through the 4R70W and I was running some 275/60/15 MT drag radials with 20psi in them. I was 60' in the 1.7 range spinning through 1st and short shifting 2nd.
crownaviation
http://www.tudyno.com/
Broke dafuk down
I have Nitto 555 drs 305/35/20. I was not dattaloging on the last outing(computer was dead) but I had on the two before that so I felt ok with it.
As for the suspension, here is a full mod list of the car.
: Engine
· 05 up Ford aluminum block
· Manley 18cc dish pistons 9.0/1 .030 w/ ceramic coated tops and dry film coated skirts
· Manley Billet Pro Series rods coated w/ PD14
· Kellogg 3.75 stroker crank coated w/ PD14
· Federal/Mogal Race series bearings dry film coated
· ARP 3v head studs
· ARP 3v main studs
· Livernois vct lockouts
· Comp 127550 cams
· Comp. Beehive springs moly coated with titanium retainers
· Ported heads with 35mm in. and 38.5mm ss valves with all ports, chambers, and valves ceramic coated
· Steeda delete plates
· MMR windage tray
· Ford GT500 oil pump w/ TSS billet gears
· Ford head gaskets
· New Ford timing chains, guides, and 2v tensioners
· Moroso 7qt. oil pan coated with PD14 inside
· MEZIERE elec water pump
· Autolite HTO plugs
· Innovators West Balancer with custom Procharger crank pulley and crank support
· MSD COPs
· MSD dual Dis 4 setup w/ 2 step and ign. Kill
· JPC sheet metal intake urethane coated by Polydyn
· FRPP polished throttle body
· Crank case evac. System and Morso breather tanks
· Remote oil filter
· Rear head coolant mod
: Power adder
· Procharger F1a with 12 rib pulley . Blower inlet and all piping ceramic coated outside and PD14 coated inside
· Procharger Red Race valve and 44 mm wastegate
· Procharger intercooler
· Custom 4" CAI with filter located under headlamp
· Custom Billet 12 rib setup
· HSW N2O wet kit with polished bottle, bottle opener, perge, blow down tube, Microedge, and all black and silver ends
: Engine compartment
· Derale 16 pass oil cooler
· Derale 4 pass PS cooler
· Battery relocated to trunk , mounted in polished alum box
: Exhaust
· ARH ceramic coated headers 1 3/4 tubes w/ 3" collectors
· ARH 3" O/R x-pipe ceramic coated
· Magnaflow 3"cat-back
: Fuel system
· Fore triple pump hat with 3 Walbro 255 pumps
· Dual MSD BAP setup (currently not connected)
· FRPP 62mm TB
· Areomotive fuel rails
· Simem Deka 80lb injectors
: Transmission
· Lentec Strip Terminator w/ TB and AVB
· Lentec Billet 3800 stall
· Trickflow alum. Pan
· Duel Derale 16 pass trans coolers
· Outlaw shifter
· 1 pc. Steel driveshaft w/ Chromalloy yoke and flange
: Rearend
· Ford 8.8
· FRPP 3:73 gears
· Detroit True Track
· 04 style pinon yoke
· Moser 31 splineaxles
· Moser rear cover with bearing supports
· Welded tubes
· C-clip eliminators
:Tires
· Front tires : BFG G-Force 245/40zr/20
· Rear tires : Nitto 305/35r/20
: Suspension
· Totico D-Spec adj. shocks
· Eibach Sportline springs
· BMR adj. UCA
· BMR LCA
· BMR LCA relocation brackets
· BMR adj. panard bar
· BMR panard relocation bracket
· BMR panard brace
· BMR k-member
· BMR tubular a-arms with updated bushings
· BMR rear extreme anti squat
· BMR boxed sub-frame connectors
· BMR upper poly bushing
: Brakes
· Bear 14" rotors
· Hurst line lock
· Braided SS lines
: Interior
· Custom 5pt roll bars with removable side bar
· RCI 5 pt. harness
· Custom switch panel in console for
N2O arm
Dash controls
Ign. Cut off
O/D arm
Perge
Bottle opener
N2O gauge
Microedge controller
· Autometer gauges
Trans temp.
Water temp
Oil Psi.
Boost Psi
Fuel Psi
W/B
Tach with shift light
Lol.. I think if I tried to save this list it would take up the rest of my hard drive! Very nice list indeed!
silverpoison
SoCal
Hey Billy play with your tokicos a little i bet they will help you hook better! Your car is hauling ass!
05stroker
Never enough power guy!
Bullard Tx.
I agree, the parts are there. Just need seat time.
Billy what psi are you running in the drag radials at the track? 20ish?
18 psi
LOL!
I have been, right now I have them two turns out in the rear and 6 turns out in the front.
Last night I was able to use the line lock and get a good burn out. I did a easy test pass to see if the car would hook. Next time out I let a little harder and the was able to get a 1.62 60 ft and 6.90 at 102 1/8. I had to lift shortly after though when my fuel pressure warning light flashed at me. I will have to check into the reason the rail pressure drooped below 40 psi on the run though. Looks like my fuel issues are haunting me once again. I am uploading the videos now and will post later.
05stroker
Bullard Tx.
Here are the vids from last night. Keep in mind I am not trying to race anyone, and don't care about reaction times at this point. Also notice the rubber on the track! There is a lot of big slick cars there on Sat. for the points racing. That is why I went, there is very good track prep and lots of big slicks running if you wait till qualifying is running.
Slow pull to check traction. Left at 1500 after a good burnout.
Next is the 2nd pass with a 2500 launch and full throttle till the FP light came on. Still need to look in to that. Nice 1/8 numbers though.
silverpoison
SoCal
Here try this setting....
4 turns from stiff to soft in the rear
3 turn from stiff to soft in the front
if you go 6.6x just with adjustment send me a Happy Meal....lol! :boobies:
05stroker
Bullard Tx.
4&4 is how I roll on the street.
johnnyv8
South Jersey
Your on nt555r correct? Why don't you try the nt05r? That's a much softer drag radial.
05stroker
Bullard Tx.
Last I checked they didn't make the same size as 555r?
They make a 275 and a 315 I think I can get the 315 in there. I will have to check. The 275 shows to be 10.6 wide and the 315 is 11.0. I want to say my 305 555 drs are 10.5. I need to look.
Mike K
WANNA BE FAST
Richfield, MN
I've got a nitto invo in 315/35/20 on a 10" rim so you should be fine plus it looks so great from the back.
TexasBlownV8
Formerly TexasBlownV6
Central Texas
Sounds like we have a growing membership of the Massive Mustang Monsters of Texas !
I'm expecting a couple 9.x runs this fall as well.
05stroker
Bullard Tx.
Should be a fun spring meet!
I can tell you he is more than ready for Mexico, he does handle the language pretty well, lol.
For Mexican Spanish. LOL Torlrlrlrrlrrtia!!! Mason had a great time when you where here. And it was funny hearing someone tell me I have a Mexican accent when I speak Spanish. (That's all we know here) And thanks for the tuning even though it was not the easiest tune file you have ever built.
But yes I can order some tasty drinks in Mexico or find a good race in "Mexico".
