one eyed willy
Pizzle fo shizzle
Subbing, I can't wait to get back to the track, I'm almost ready!
I have Nitto 555 drs 305/35/20. I was not dattaloging on the last outing(computer was dead) but I had on the two before that so I felt ok with it.
As for the suspension, here is a full mod list of the car.
: Engine
· 05 up Ford aluminum block
· Manley 18cc dish pistons 9.0/1 .030 w/ ceramic coated tops and dry film coated skirts
· Manley Billet Pro Series rods coated w/ PD14
· Kellogg 3.75 stroker crank coated w/ PD14
· Federal/Mogal Race series bearings dry film coated
· ARP 3v head studs
· ARP 3v main studs
· Livernois vct lockouts
· Comp 127550 cams
· Comp. Beehive springs moly coated with titanium retainers
· Ported heads with 35mm in. and 38.5mm ss valves with all ports, chambers, and valves ceramic coated
· Steeda delete plates
· MMR windage tray
· Ford GT500 oil pump w/ TSS billet gears
· Ford head gaskets
· New Ford timing chains, guides, and 2v tensioners
· Moroso 7qt. oil pan coated with PD14 inside
· MEZIERE elec water pump
· Autolite HTO plugs
· Innovators West Balancer with custom Procharger crank pulley and crank support
· MSD COPs
· MSD dual Dis 4 setup w/ 2 step and ign. Kill
· JPC sheet metal intake urethane coated by Polydyn
· FRPP polished throttle body
· Crank case evac. System and Morso breather tanks
· Remote oil filter
· Rear head coolant mod
: Power adder
· Procharger F1a with 12 rib pulley . Blower inlet and all piping ceramic coated outside and PD14 coated inside
· Procharger Red Race valve and 44 mm wastegate
· Procharger intercooler
· Custom 4" CAI with filter located under headlamp
· Custom Billet 12 rib setup
· HSW N2O wet kit with polished bottle, bottle opener, perge, blow down tube, Microedge, and all black and silver ends
: Engine compartment
· Derale 16 pass oil cooler
· Derale 4 pass PS cooler
· Battery relocated to trunk , mounted in polished alum box
: Exhaust
· ARH ceramic coated headers 1 3/4 tubes w/ 3" collectors
· ARH 3" O/R x-pipe ceramic coated
· Magnaflow 3"cat-back
: Fuel system
· Fore triple pump hat with 3 Walbro 255 pumps
· Dual MSD BAP setup (currently not connected)
· FRPP 62mm TB
· Areomotive fuel rails
· Simem Deka 80lb injectors
: Transmission
· Lentec Strip Terminator w/ TB and AVB
· Lentec Billet 3800 stall
· Trickflow alum. Pan
· Duel Derale 16 pass trans coolers
· Outlaw shifter
· 1 pc. Steel driveshaft w/ Chromalloy yoke and flange
: Rearend
· Ford 8.8
· FRPP 3:73 gears
· Detroit True Track
· 04 style pinon yoke
· Moser 31 splineaxles
· Moser rear cover with bearing supports
· Welded tubes
· C-clip eliminators
:Tires
· Front tires : BFG G-Force 245/40zr/20
· Rear tires : Nitto 305/35r/20
: Suspension
· Totico D-Spec adj. shocks
· Eibach Sportline springs
· BMR adj. UCA
· BMR LCA
· BMR LCA relocation brackets
· BMR adj. panard bar
· BMR panard relocation bracket
· BMR panard brace
· BMR k-member
· BMR tubular a-arms with updated bushings
· BMR rear extreme anti squat
· BMR boxed sub-frame connectors
· BMR upper poly bushing
: Brakes
· Bear 14" rotors
· Hurst line lock
· Braided SS lines
: Interior
· Custom 5pt roll bars with removable side bar
· RCI 5 pt. harness
· Custom switch panel in console for
N2O arm
Dash controls
Ign. Cut off
O/D arm
Perge
Bottle opener
N2O gauge
Microedge controller
· Autometer gauges
Trans temp.
Water temp
Oil Psi.
Boost Psi
Fuel Psi
W/B
Tach with shift light
I think you will be able to accomplish your goal pretty easily once you get comfortable with the car.
Billy what psi are you running in the drag radials at the track? 20ish?
Lol.. I think if I tried to save this list it would take up the rest of my hard drive! Very nice list indeed!
Hey Billy play with your tokicos a little i bet they will help you hook better! Your car is hauling ass!
I have been, right now I have them two turns out in the rear and 6 turns out in the front.
Here try this setting....
4 turns from stiff to soft in the rear
3 turn from stiff to soft in the front
if you go 6.6x just with adjustment send me a Happy Meal....lol!
Your on nt555r correct? Why don't you try the nt05r? That's a much softer drag radial.
Last I checked they didn't make the same size as 555r?
Sounds like we have a growing membership of the Massive Mustang Monsters of Texas !
I'm expecting a couple 9.x runs this fall as well.
Fuck ya !!!!! Makes 3 of us, my car will eventually be built to play on long open roads in Mexico
I can tell you he is more than ready for Mexico, he does handle the language pretty well, lol.
