One more 15X8 rim option on the cheap!
xtweakerx
Get SOME!
Palm Beach, FL
urgh u have an 05 :(
wish it was 07+
i heard the 07+ are a bit different when it comes to fitting the 15 inch rims.
ive heard 05+'s ussually can get away without modifying as much to fit 15inch rims but 07+ have to modify, i dont know if the brake calpier size may be different or something else? anyone want to shine some light on it
ROUSH STAGE 4
ANIL8R
Somewhere in Texas, in the fastlane...
wish it was 07+
So long as you don't mount a tire on the rim, you can send it back if it doesn't fit. Just in case no one knows for sure about the '07's.
MexGT
Mexico
wish it was 07+
never heard of that before
Wyld
408 C6
DFW Tx
wish it was 07+
Buy them and let me know if they fit, then I will get some.
US-1
Banned
The ShadowLands
wish it was 07+
Where the hell did you hear that?
<I think he made it up to have something else to worry about.>
:roflmao:
Nice to know you're willing to "take one for the team" there Wyld.
:laughlots:
Dex
I'm Dexolishous
Utah
too bad we cant find a 15x10 to work and be cheap. I think with 850tq I need the extra tire so it looks like I have to go with a 10" rim.
don_w
Dyno Numbers - Who Cares?
San Diego, CA
Do you think you can put a 28x10x15 MT Drag Radial on thoses ?
Last I knew, M/T did not make a drag radial in that size... is it something new? Or are you referring to the 275/60-15 (#3754R), which they call out as an equivalent size to a 28x11.50-15? It has a 28" dia, 9.5" tread, and 11.0" section. If so, M/T recommends a 7.5"-9.5" rim, so that would work, too.
Dex
I'm Dexolishous
Utah
whats the biggest slick/tread width you could get away with on a 8" rim?
US-1
Banned
The ShadowLands
Yup. That sucker is 28" x 10". Seen plenty of them on 8" wheels too.
You can put a 10" tire on an 8" wheel. Not optimum but it works fairly well.
ROUSH STAGE 4
ANIL8R
Very nice !!!
:clap:
I'm searching for new daily rim and tire.
But with the 3D Carbon body kit my fender are wider, do you have a picture to see how near the tire is from the fender, the best would be to have a tire that stick a little out on your setup, to match mine ;p
I re-read your post...seems like this might be what you are looking for with a set of swaybar relocation brackets...it just might work for your setup? It won't be enough backspacing for the rest of us though!
http://store.summitracing.com/partd...793325+4294755963+4294795084+115&autoview=sku
Dex
I'm Dexolishous
Utah
wonder if there room to make the backspace bigger? Shave down the inside of the wheel?
Even the 3055 28.0/10.5-15 still needs a 10" rim. That would be a pretty big "muffin top" and not sure if i would wanna squeeze that onto a 8" rim
don_w
San Diego, CA
Not true... M/T recommends a 9.0" - 11.0" rim width for the #3055. In fact, that is the exact tire I used to run on my 15x9 Weld XPs. It worked great.
Dex
I'm Dexolishous
Utah
So you think putting it on a 15x8 would be ok?
xtweakerx
Get SOME!
Palm Beach, FL
ok i guess, i heard it was a rumor from other message boards, so i guess if it works on your 05 it will work on my 07 and yah ill try it evenually.
Noone has any input on what size tires i should go for my setup, front and back for the ET Streets?
Stock Height, 4.10 gears, N/A.
Im currently on stock front tires and M&H 275/50R17 Drag Radials out back.
US-1
Banned
The ShadowLands
Dude....can't you go to M/T's site and read the damn chart for yourself?????
http://www.mickeythompsontires.com/strip.php?item=ETStreet
#3758 is a 27x10.50-15LT. Weighs 22 lbs; M5 compound; recommended tube is the part number 9553; measuring wheel is 8"; 27" tall x 9" tread with a 10.6" sidewall width and has an 85" circumference.
For the front: #3007 is a 26" tall x 4.5" wide ET Front.
http://www.mickeythompsontires.com/strip.php?item=ETFront
Or the #1573 is a 26" tall x 4.8" wide street style front tire.
http://www.mickeythompsontires.com/street.php?item=SportsmanFront
Happy now?
Enitalp
The lost guy.
Canada, QC
As usual, you're right. Was watching a lot of tire yesterday and my mind mix up all those.
Here is the one i was refering too.
Sportsman S/R Radial
28'' x 10''R x 15''LT
http://www.jegs.com/i/Mickey+Thompson/672/6640/10002/-1
