S&H Turbo Kit Build
weather man
Persistence Is A Bitch
MN
Hope you make yours all work out Brian
I know Danny at DB Performancecan make it work, but he is gonna have clear instructions...if it bogs down, the kit is coming off. The problem is I am doing a cam swap with my Lunati cams. I told my trans guy to go ahead with putting the 4R70 together. I have visions of cluster fuck dancing in my head! So...worst case, I could have $5,000 of turbo kit and a built 4R70 with converter setup for turbo HP sitting in my shed. :helpme:
Makdaddy
I am Dysfunctional
South of Chicago
I feel Ya
Ill be hoping or the best
If its any consolation I already hit 12 Lbs of boost with my intercooler
All by accident of course
Sorry Op for :tj:
weather man
MN
When LITO says we are done I will go to the dyno for a number. Now first gear tire smoke, second gear tire smoke, 3rd gear pulling hard, and smiling all the way.
Glad your install is going the right way!
06stangia
Iowa
I am running large red 6psi and small yellow 2psi but gauge shows more like 9psi. I am planning on running the car at rock n rods this year. Any of you planning on coming?
06stangia
Iowa
Also Makdaddy that is how I am running my shaker system if I remember I will post a picture latter.
Sprayer84
Omaha, Nebraska
I am definitely going to be there. My buddy and I will be there from the 19th - 21st. He's bringing a built AMC Javelin.
06stangia
Iowa
Here it is with the shaker.
06stangia
Iowa
Is this the normal height of this pipe or do i need to get it up more. As you can see i already drug it on the driveway.
ctt326
Brenspeed Hater
Fort Wayne, IN
You can get it up a little more, use a jack to jack it up while the v-band is loose then tighten it up. But it will always be kinda low and drag on shit.
06stangia
Iowa
Thanks guys anyone running the ford racing zero degree plugs if so how did you gap them?
