I can't wait to see this build - I was just over checking a similar one in the 4.6 tech forum. It's unreal how much money you can bury in a car that has variants at a $20,000 price point!
I'm already 60k deep in this car including the original rebuild when we bought it wrecked, not including the 10k for the R-spec. I'm looking to drop another 10k on brakes and a full floating setup, a few thousand on an axle, plus 10k finishing up my griggs setup. I've also got a few thousand to spend on a cage and wiring harness through Vorshlag.
No idea what this next motor will cost, but I would guess at least 20k. Probably closer to 30k depending on which route I go.
If I can make it out the door under 150k total, I'll be happy. The money isn't important at this stage. This is about building a car I can race in anything and do well, and learning more about everything.
Once I get settled into my permanent position this summer I'll probably start a build thread. Right now I'm saving as much $$$ as I can.
Talked to Darton today. They confirmed most people go with a 94mm bore and it's MUCH stronger than the factory setup. They also said they've had zero failures when they do the installation, and there is a lifetime warranty against manufacturers defects on the sleeves and one year warranty on the installation. Not too bad.
I emailed them back to see about some specifics. Prices, what they recommend for other stuff like clearances and what not. I'm halfway tempted to let them do all the machining on the block since I'll have to ship it to them anyways...
Can anyone tell me if GT500 4v heads will bolt up to the 3v block without modifications of the oil and cooling passages? What about the 4v terminator heads?
Reason I ask is the guy mentioned something about having to modify one of the oil passages in the head to work with the sleeves. He said the 4v heads are correct, but idk if he meant the terminator or GT500 heads. I asked him to clarify but I want to double check here.
