Tuners help please, Maf nearly maxed??
ARMORINE
tulsa, oklahoma
i have a 2007 Shelby GT with an eagle stroker, 300 CI 4.6 3v N/A engine. max effort off the shelf build, stage 3 MHS heads with oversized valves, 2013 gt500 injectors, comp 127600 cams, frpp intake, FRPP twin 62mm throttlebody, jlt series 3 110mm CAI, 11.5:1 compression ratio, E85 fueled.
long story short my OEM MAF is nearly maxed out. i don't understand how this is possible. i know guys have run over 600 on stock maf. I'm pulling 225 maf counts at idle, around 1.4v. almost 900 MAF counts at around 6k and still have 1200 RPM till i hit rev limiter. i dont understand how this thing is pulling this much air. has any one had this issue before? its pulling so many MAF counts my tuner is having alot of trouble getting it to switch tables and crank timing in. it pulls great till 6k then it goes wildly rich, he's saying theres not enough data points left to properly smooth out the AF. im not sure what to do at this point. hes as lost as i am at this point. he suggested getting a gt500 MAF sensor and seeing what it does. any help would be greatly appreciated. thank you.
lito
Caracas, Venezuela
I smell some BS here, and the GT500 is the same MAF, your tuner should know that.
ARMORINE
tulsa, oklahoma
are they? i dont believe they share the same part number. i'll have to look now.
the counts are real. were both scratchin our head here as to why its pulling so much air. i could have some other issue though and not be pulling so much.
46addict
13726548
Lawrenceville, GA
A new Mafia will cost as much as an SCT BA5000 or equivalent. I've had a couple tuners tell me the Mafias are fail prone and I've experienced issues with them first hand. I would just get a real MAF and be done with it.
ARMORINE
tulsa, oklahoma
im going to the shop today. my buddy just bought out a local shop that specialized in mustangs. were gonna dig through their stock. id be hard pressed to believe we wont find a better MAF sensor. those guys had been in business for nearly ten years and never threw anything away. if we don't find one im just gonna order a BA5000.
RocketcarX
95% of my weight is fuel
Colorado
There is no way an NA build needs an extended range sensor, your MAf scaling is likely off, injector size, some parameter like that.
CammedS197
Palm Bay, FL
Hey I would honestly get with Lito. Something is clearly wrong. I'm at 3.98 volts and have hit 4.00 volts on mine na and I'm just your standard bolt on 3V cammed and exhaust. Thats reving to 6750rpm. Never had an issue. No Idea what the MAF's limit is anyways.
Marble
Shasta county CA
Or maybe have your tuner chat with someone and let them look at the logs and tune.
Even some of the better tuners end up getting stumped sometimes.
Its not a physical maf issue especially if its in draw thru still. I would wager its injector to maf scale issue in the tune.
