I went with Steeda too, but did the spherical bearing on the diff and rod end on the arm. Most people would hate the noise, but the sound of the 4.10s winding up and down is reminiscent of the in car shots of LM cars at Lemans (or similar). It’s fucking awesome!!
Wife can’t stand it, I don’t care LOL
How was the install of the Steeda bushing?
The On3 kit is fine if you go into it knowing that it will not fit properly without some minor work. I'm pulling my hot side piping out to modify. Just got my mig set up today. The wastegate piping is too low. My car sits fairly low, so it can be a problem. Other than that, expect to beat to fit, paint to match.Ok. Looking for negatives on the On3 kit. Thank you
Very Time Consuming. Cleaning the rubber out, and leaving the outer sleeve of the old bushing in place (without damaging, or weakening it) is a PITA. The urethane bushing fits inside of the old-bushing-sleeve. It’s fairly noisy at times as well.How was the install of the Steeda bushing?
The urethane bushing isn’t exactly quiet either. I don’t mind it much, except that it knocks really hard/loud when rolling over sharp bumps or dips. It sounds like something is loose and knocking around (but it’s not AFAIK).I went with Steeda too, but did the spherical bearing on the diff and rod end on the arm. Most people would hate the noise, but the sound of the 4.10s winding up and down is reminiscent of the in car shots of LM cars at Lemans (or similar). It’s fucking awesome!!
Same knocking sound on this version. Must be a Steeda thing. But like you said, tightened everything up, so I have no complaintsThe urethane bushing isn’t exactly quiet either. I don’t mind it much, except that it knocks really hard/loud when rolling over sharp bumps or dips. It sounds like something is loose and knocking around (but it’s not AFAIK).
Meth injection, good call. Thank you for adding to my to-do list LOLIt's a lot more challenging to keep the IATs of a forced induction set up closer to ambient simply because compressing the intake gases generates heat.
You can at least fit a large intercooler behind the front bumper if you have a turbo or a centrifugal blower, and this makes it easier to limit the rise in IAT when driving hard. However positive displacement blowers have their own water (coolant) cooled heat exchanger and since underhood space is limited, the heat exchanger is small and requires a pump to circulate coolant from a separate tank to conduct the heat away.
Installing a water-meth injection system to provide additional cooling of the intake charge might alleviate your problem.
