What RPM are you launching at?
oktw88
Oklahoma
What do you guys launch at on slicks?
My car is NA with cams, exhaust, gears and suspension. What would be a good RPM to launch at on slicks at the track. My best ime right now is a 12.96 @106 with a 1.88 60ft spinning some because i had my tires at 26PSI..
marcspaz
~Resigned~
I was leaving at 7000 RPM WOT on days when the track prep was dead on. Dumping, not slipping. If prep was off, I would still leave at 7k WOT, but I would slip it like a mo fo! LOL My best short time was 1.68.
I would get just a little wheel spin (barely a chip or two). Without a TruTrack LSD or locker, you may not be able to pull that off though.
chad05gt
Lake Charles, La
I cant pull that off... w/ TruTrac :damnit:
marcspaz
~Resigned~
Slick M1 compound tires at 14 PSI hot (10 cold). It was some seriously scary stuff on the big-end. The trick is to make sure the tires are good and hot so they balloon to 14 PSI or the bead will break loose.
At 3800 lbs, I had some advantage with traction...
06GTMustang89
Corner Carver
Cary Area, NC
or wheel screw those suckers in there....or set them to 12 or 13ish and do a lighter burnout which mickey thompson recommends
jp's performance
shooting for 11.60's N/A
mass
6800rpm 26x11.5x17 bias ply et streets.1.62 60ft 4.30's stock clutch and posi stock driveshaft
dragpac
easton,pa
I have a tru trac posi,stock clutch and drive shaft.and yes I'm suprised my driveshaft is still holding up.
SlvrS197
i have stock posi, and d/s and i usually dump it at 6000-6200
on 26x11.50 ET streets 1.60 60's
alloy6ix
Wiener Dog Racer
Big ass state shaped like Texas
I launch at 6200rpms
26x11.5x15 et street
stock posi, stock clutch
^^ Bitch. lol. :kidding:
FWIW, not that anyone here gives two shits, but launching an NA v6 with the stock 18" BFG's, stall at just under 3K and dump the clutch. I've seen a 2.2 60ft with those. A friend of mine who used to have an 07 4.0 hit a 1.9x 60ft with ET streets on stock 16" v6 wheels with only JLT, AM tune, T-Lok, and 3.73s. I can't wait to put my spydershaft to the test by January..
circusboy
Last time at the track I was leaving at @ 5000 RPM, on ET Streets and skinnies up front. no slip, just dump and go, lol. pulled three 1.6's 60' in a row.
Now for my question, lol. I'm now Turbo, should I launch any different?
I was thinking maybe at the RPM that I'm making peak torque or should I just let here eat :naughty1:
Freaknazty
KEYBOARD NINJA
SOUTH LOUISIANA
3700ish was my sweet spot....... less gear than you though but on 25" tall tires ......last time out at the track I was dumping it at 6k ( just couldn't get those damn shifts right though lmao )
