WarFords
Are you running sportline springs? And what 2 step are you guys using?
Well after a long week and a lot of support from all of our friends Jake@Power By The Hour got a chance to check the car out. We did a leakdown and compression test and the motor passed with flying colors. The plugs were swapped, a new alternator was put on the car and we made a few other tweaks. We also believe we figured out why the car was acting the way it did last time at the track.
None the less we'll be picking up the car tomorrow and throw it on the dyno at UPR just to make sure it's all good. Then it's off to the track.
Thanks to everyone for their support. Jon L., Jeremy@UPR (Huge Thanks), Al Papitto and Jake@Power By The Hour.
Hopefully things work out well tomorrow and we can post some new times.
Jared
Jared,
can you tell us where the water was going from the overflow tank ? If there wasnt a had gasket leak where would it go unless you had a leak somewhere ?
Jared, I had to top my tank off several times after my build, it took several days to level out. Merry Christmas to you and good luck you lucky dog, our track here in St. Louis closed in October, so we won't know what we have till spring. BillCome to find out there was loss of coolant. The car was put together and barely driven before going to the dyno. At the dyno the coolant tank was full. It was never checked after that until we took it to the track. It must have been an air pocket either in the motor or somewhere else in the coolant system that finally made it's way out. However it wasn't noticed until that day at the track because no one checked the tank level until then.
We'll be at the track this Wednesday. I'll report back then.
Jared
Congrats on great looking and performing car...now go out and run a 9X
Jared..What width tire is that on the rear?
This is the first time I looked over this thread.... Jared is making very valid points and all you guys can't passed what other people are making on other dyno's with a lesser blower blah blah blah. Like Jared said et's are what matters I know when I slap my gt500 long block in my car I will be putting a 4.0 whipple on it. Im tired of hear " my buddy's car made XXX hp and ran 2 seconds slower then it should... also don't just look at peak hp numbers because who gives a dam? It's all in the set up and this car has it going on. I can't wait till these guys really start pumping out more boost out of this 4.0.
Jared I fought that same bouncing issue with my car and sportlines... even with the qa1's it didn't solve it. Change the springs and the car is a differn't animal.
Ps- for all you guys NOT impressed if you can do better.. go for it.
vids vids vids vids vids vids!!!!!!!!!!!!!!!!!!we cracked off a [email protected]
