drbobvs
Went to the Mustang Dyno again since I had my JDM and VMP tunes "updated". Justin from VMP added 2% more fuel this time and the JDM hesitation issue has been fixed.
The weather was about 15 degrees warmer this time and the oil temp was 190 degrees at startup. I had just gotten back from giving someone a "demo ride" too, so the car was driven hard before the run.
Since my last run I added BBK shortys and a new tensioner. Here's the sheet from 4/24 and the 2 sheets from yesterday RPM vs MPH.
Now I know heat can deplete power but at some points I'm down nearly 40 Ft-lbs!! The boost is down about .4 psi, perhaps from the heat too but maybe partially due to the headers also. I've emailed JDM to get the AFR into place, so hopefully they can do that this week.
Does heat really make that much of a difference day to day?? The car sure feels strong but I just can't believe the sheets. What do you guys think?
