Maximum motorsports is the go to Caster/camber plates. I have them and am lowered 1 inch on pedder springs. I purchased my car with the Ford Racing lowering kit and K springs. Too much bounce on my roads, and scrapping all over the city. Was tight and low body roll. Currently on pedder springs, it is a 1" drop. Front has some progression to them, rears are linear. Paired with Bilstein shocks. A little less body roll compared to the Ford racing Kit, but never scrape or bottom out. Kenny Brown K-member and rear location brackets with upper and lower control arms. Improved handling a lot and dropped some weight. I have also ran this with the Steeda Adjustable front and rear sway bars with FTBR front end links. Car feels much better. Selling the Steeda and FTBR (Full Tilt Boogie Racing) suspension parts now, as I am looking to go true coilover with stiffer springs, so have moved to smaller sway bars, so springs can do the work. Only thing the nice coil overs are pricey. And will probably getting the JRI system. Also, you can go with a Watts Link, Whiteline and Cortex are popular. I personally, like the Cortex better, and they are about the same price. Cortex has more adjustment, options of poly bushings or spherical rod ends, has 4 adjustments vs 2 on the Whiteline, and Cortex even has a hookup for a diff. overflow can. If you want to jump up to some more Bling you can run the Kenny Brown 4.5 Rear grip Kit, no sway bar, you will need true rear coil overs, but its as close to a IRS as you can make a solid axel car. It requires real heavy rear spring rates.
Don't forget to consider what tire setup you will be running square vs. staggered, as it will also affect handling.
