Compression and boost. Originally from WTB: OEM Block or Forged Shortblock
Dubstep Shep
WUB WUB VROOM VROOM
Houston, TX
I'm looking for one of two things for my engine rebuild. Been perusing the forums but hoping this thread turns something up.
I'm looking for either an OE 05-10 4.6L aluminum engine block or the same block, but with a forged rotating assembly.
Looking to do no more than $600 shipped for a block. I'm in Oklahoma and a shipping quote to any corner of the nation for just the block shouldn't be more than $125.
Price for the short block a assembly will obviously depend on components. Short blocks that need assembly are fine. Looking in the 2k-4k range right now.
I should also add I'm looking for short blocks stroked to a 5.0L at this point.
Might have a block... Will update when it's for sure
^ The FRPP Aluminator is $4600 shipped from Tousley. This was my top choice for a short block based on Ford Racing's reputation for honoring warranty issues. I know a guy who just got a FRPP engine replaced after spinning a rod bearing after about 350 passes at the race track. Every other engine builder will tell you to go pound sand even if you have a legitimate issue, almost nobody ever pays out on warranty claims.
The only reason I got the JDM 302E was because I purchased it second hand but still new in the crate. It was about $1100 cheaper than a new short block so I decided that was enough savings to justify losing any warranty.
Hard to really get a fix on this one though. MSRP is $5300 and they aren't even rated for anything. At least not that I've heard of
Ratings are overrated. They don't mean a thing unless destruction testing and random samples are done.
You might want to search any prospective motor companies reputation on the forum. No holds barred here, you will get the real scoop.
If you change your mind about having a stroker I still have a 4.6 longblock with new style heads, 11:1 compression Mahle pistons, h beam rods with arp2000 bolts, stock crank so you can use your 6 bolt flywheel, and a few other items on it for $2500. You arrange shipping. It has a few issues that don't affect performance. Things like a thread insert in the crank, 25,000 miles with about 10,000 of that boosted. It ran fantastic when I pulled it a month ago.
rayS197
virginia beach, virginia
Correct. Mine was $4600 shipped to my friends shop. For under $4800 I purchased the block, head kit and the steel tensioners. To get a better understanding about the SB and for any questions. Call the Ford Racing 1-800 # and ask for Ray. And no thats not me. :crazy:
These mod motors love compression. My tuner specializes in twin screw blown modular motors and he prefers higher compression.
Dubstep Shep
WUB WUB VROOM VROOM
Houston, TX
So how does motor compression compare with blower compression? I.e. If there's only so much of an overall compression ratio you can run, which offers more power? I imagine there's more too it than that lol. A lot more.
Lol you ran over an 11 compression ratio with boost? Brave man haha!
I ran 19psi with 10.76:1. Keep in mind that most of the posters on this site have experience with what they post about. It's a huge difference from sites where posters repeat what the cool kids say just to sound cool.
As several owners have proven here on this forum, these motors can handle 22-24 lbs of boost or more. How big of a blower do you own and how much boost does it make? A higher compression motor will make more power both on and off boost. Proper tuning and good fuel will take care of the detonation concerns. In my case, my blower can only make about 15-16 lbs of boost. I wish to maximize performance within that constraint because I'm not going to spend another 8K or more swapping blowers.
W3bb3r04
Slow 3v Member
Clinton, TN
Was that on pump gas though?
Edit: Try these to see what difference more compression makes with a boosted motor. In a 3v 11:1 gives you about the same cylinder pressure as stock compression with 3 more psi of boost.
http://www.wallaceracing.com/Calculators.htm
Best performance was with e85. I've run it with 92 pump but turned the spark advance down.
Why would it matter what the fuel was? Not too many people are going to run high boost with pump gas. The point is that a higher compression motor will make more power with less boost.
