Learning to make fast go fast!
05stroker
Never enough power guy!
Bullard Tx.
05stroker
Bullard Tx.
I've seen clogged vents on motorcycle cause the tank to cave in.
Interesting!
No roll-over valve on mine. I honestly don't see the need for one if you put the end of the vent tube low enough and also the check valve I used should somewhat serve a similar purpose.
If this vent fixes my issue I will look into it.
dysan
Dis-Member
Williamstown, N.J.
Well, the issue is that they only offer the one I am using in a -6 size so if you want to use -10 then it won't work.
travelers
Eastern Pa
I do like the sound of the 2way check valve. It looks like the small vent on the cap just wasn't enough to handle all 3 pumps and created a vacuum in the cell. Good luck nest Sat......
I have also seen motorcycle tanks collapse
travelers
Eastern Pa
Dam that's some bad luck, I hope they have an idea....
Just a thought, I would disconnect your feed line up front and connect another line to a bucket and see what kind of flow you have before and after the regulator
dysan
Dis-Member
Williamstown, N.J.
I don't know if that would work correctly because aren't the regulators boost referenced somehow?
05stroker
Bullard Tx.
My Fore regulator is boost referenced. Fuel pressure is fine until about 6k and then it drops like there is not enough pump.
