SoundGuyDave
This Space For Rent
- Joined
- Apr 9, 2007
- Posts
- 1,978
- Reaction score
- 28
I decided to post this here, rather than in the main forum, since the drag guys don't seem to have any concept what "part throttle" is...
I honestly know JUST enough about camshaft specs to be dangerous, so I'm hoping that somebody(s) that really understands how a cam will react based on the specs would be willing to chime in and share the tech.
As you folks know, I'm running TT with NASA, and am thus spending "points," so dollar cost is not the overriding concern, but fitting into a class restriction is. Basically, what that boils down to, is that I have to run bone-stock heads, stock valve sizes, but the cams and valvetrain hardware are both essentially open for discussion. ECU tuning is obviously wide open, as well. PLEASE do not recommend turbos or blowers, the points cost is INSANE. The car weighs in at 3600lbs, with a stock 3550 trans, and a 3.73 gear set in the rear.
I came up with a few contenders, including one specifically recommended by a cam manufacturer, but I would love some informed opinions. What I don't want to do is start playing musical camshafts through the season.
............................adv.......adv..........0.050.......0.050.......lift........lift.....
CAM....rpm.range....intake....exhaust.....intake......exhaust....intake...exhaust....LSA
Stg1....900-6700.....256.......267...........221.........228.......0.523......0.538......112
Stg2....950-6900.....264.......275...........229.........236.......0.535......0.550......112
FRPP.................................................221.........240.......0.472......0.433......110
BBR1..1500-6000.....270.......276...........227.........233.......0.480......0.480......114
BBR2..2000-6500.....284.......294...........241.........251.......0.492......0.492......114
Three manufacturers are represented, each with an obviously different philosophy in cam design. The comp cams tend to be conservative with duration, but very aggressive with lift, where the BBR cams are the exact opposite. FRPP seems to land in the middle, but has the narrowest LSA of the three.
FWIW, comp recommended the Stage I cam. Obviously, I'm least concerned with peak HP/TQ numbers, but want the largest possible area under the curve, and the powerband can't be peakey, as you folks are well aware.
I'm absolutely NOT concerned with idle quality, "lope" characteristics, sound, etc. This is all about power. I don't know if I will get it, but I would like to see power in the 350-360HP range (power-to-weight ratio limit is 357.5HP at class minimum weight of 3450, which I want to get down to eventually). I'm also hoping to pick up some more revs at the top end, since with the shorter tires, I'm finding that I have to make one more shift on some of the medium-length straights than I really want to. Each upshift=time wasted...
Supporting mods include a C&L Racer CAI, Steeda billet deletes, ARH 1-3/4" longtubes, offroad-H pipe (no cats), EH2O pump, and Roush UDP setup.
