- Joined
- Sep 15, 2007
- Posts
- 3,065
- Reaction score
- 5
World's Fastest and Quickest 3V with (non-centri) Supercharger
Mike did some testing on his new combination. We are after the goal of fastest Supercharged 3V period. I noticed this is the fastest of the non centri blowers. His car is also doing it on a smaller engine blower combination than most!
Mike's car has the same combination as our 2007 Roush Drag pack car, in fact most of the parts on his car came from that. We have plans to do a coyote swap with the Drag pack so Ill keep you guys informed when we do! The engine is our JDM Engineering 302 E stroker Longblock complete with our CNC Race ported 3v Cylinder heads, oversize valves, and custom grind Comp camshafts. The cams are locked out and degreed in with a set of billet adjustable cam phaser lock outs. The engine was built for Mikes car in house by our engine builders Tommy Martino and Matt Kennedy. Im sure most of you can notice we changed the front accessory drive on the engine as well. We relocated the alternator to the passenger side with a kit we designed for the Cobra jets a couple years back. Also deleted Power steering and AC. We have a Thumperr Tensioner, electric water pump, ATI balancer, and 10 Rib Shelby GT500 supercharger pulley on top. The car makes just under 20 psi boost with this pulley combination. We shortened up the belt length considerably by doing all this which has been great for preventing any belt slippage.
The Roush TVS supercharger has a Ford Racing Super Cobra Jet monoblade throttle body and Ford GT Supercar inlet boot that mates up the a Ford Racing Cobra Jet 123mm MAF housing.
This combination helps to maximize airflow into the supercharger. The car runs factory ignition coils and Ford Racing 12mm spark plugs gapped at .024" on an otherwise stock ignition system. The car gets fuel via 80lb/hr fuel injectors, stock rails & fuel lines, and a GT500 fuel system. Nothing more. The car does run VP C16 racing fuel which helps protect against detonation at these high boost/power levels. We run Kooks 1 3/4" - 3" Longtube headers, a 3" Catless H pipe, and a 3" Magnaflow Catback exhaust. 4.30 gears are in the stock 8.8 housing with welded axle tubes, Detroit Locker, and upgraded Axles. Running Hoosier 30x9x15 Full slicks on 15" Bogart wheels all around.
