Need some help knowing if this set up would be safe
Travis Johnson
Hey everyone
So I feel a bit lost while trying to research proper fuel delivery for my turbo kit and it's fuel injectors that will come part of it. Its a on3 Performance Twin setup for my 2014 5.0, and I'll be using the 1050 CC injector dynamics, will using a fuel pump such as DeatschWerks pump be safe and efficient for the 1050 CC injectors? It says its flow rate is 100-199 Gal/Hr and 95-100 PSI of pressure, or am I just looking too much into this? Please let me know, Thanks!
Depends on how much boost and power your trying to run and what fuel. That determines overall fueling needs. Which DW pump model?
Travis Johnson
Thank you so much @JeremyH
I've been so lost on this research, got it, I will go ahead with this set up and add a wire with the pump
Travis Johnson
I might go with that when I go with this set up, is the standard kit the one I'll need?
