Bobby
turbo gt about to go fast
No just our twin kit. I an going to install an iat temp sensor. It reads 2 temps before intercooler and after inter cooler.
Should be in the 900-1000 range easily. I'm looking forward to both your's and Jeremy's kits HITTING the TRACK.
Earl
Jeremy, are you going with the same size turbos or something a little smaller? Those are pretty big turbos for less than 300 ci. They will work with Bobby's big bore stroker but I'm not sure about your 4.6L. How did the install go this past weekend?
Earl
Can't wait to see what it does with my 326 c.i. 10.2 compression frpp manifold gt 500 tb stage 2 cnc heads and E85.
Sent from my SPH-L900 using Tapatalk
FIXED
What meter is Bobby running?
Jeremy, what are your plans for the kit? How much power are you going to try to make?
