Worst motor grenade ever seen!
swflastang05
Back for More
N. Ft. Myers, FL
rofl....
agreed, when FI 80's dont exist.
Ignoring a friend with your mods and tuned by Lito was a massive fail. Taking a tune from a dude at diablo and assuming its safe was fail, not having a wideband was fail.
Tell him to get a new motor, and point him towards Lito, assuming he learns his lesson :p
atleast we see how it did so much, 4k rpm + sudden wot without tune will do it....
Yea man, before he even received everything from UPS I told him to send back that Diablo POS tuner and get an SCT & LITO, but he was excited and didn't want to listen. Lesson learned, hopefully.
JoshK
Modder AKA Fuel
Nebraska
I agree Billy. He isn't even competent enough to datalog let alone spell
Granatelli
Ouch!!!
Good News is there are plenty of great companies that offer a strong replacement.
Bad News is most likely timing of the event. He just spent all that money on a turbo kit and now he needs to drop more coin on a long block as I am sure the heads did not fair well either.
I agree about 7psi – (had to have been more) that or the driver ignored the detonation as he stayed WOT. To do that much damage took an effort to ignore the tell tail signs.
As a company that sells turbo kits and the past owner of Paxton Superchargers, I can tell you that is the biggest problem of selling turbo kits. Customer have the ability to ramp boost sky high and it comes on so fast by the time to realize they did a NO NO its too late. On the other hand with a centrifugal blower you have lower boost down low so its “more forgiving” and giver the drive more warning. Also if the driver ignores the warnings it still has a longer fuse before it blows.
Lastly when you buy a centrifugal blower most often it has a tune that comes with it the is safe – most turbo kits require a custom tune. So customers who fail to be patient end up with EXACTLY what happened here – SUCKS
If I can help – happy to do so
Weou09
Bham, Alabama
Ouch!!!
7# is a lot on a n/a tune. I could see it doing that much damage easily. Saying ignorance is a con for turbos is laughable. ANY FI and stupidity don't mix lol
mach828
Albuquerque, NM
Slightly agree with Granatelli. You go lean and detonate with a centri down low in the rpms, then your boost is really low. A stock engine can handle detonating with little boost and low torque. You'll likely never make it to full boost without detonating earlier.
If you go lean and detonate with a turbo or pd blower, you might have 450-500lbs-ft of torque at 3,000 rpms within a split second of opening up the throttle. That is a lot of force to go against and attempt to survive detonation.
Weou09
Bham, Alabama
I didn't mean that i disagreed with the theory. Just the fact that ignorance like this would have given similar outcomes regardless of the type of FI.
fdjizm
Drag Queen
NY/NJ
The question "How will my car react to a turbo?" will go down in history.
Granatelli
jewc75 - play nice :crazy:
Guys I did not say ignorance (like not knowing) I said "to ignore" "If the driver ignores the warnings the centrifugal still has a longer fuse before it blows." vs the turbo via boost curve
We install Centrifugal and PD blowers and turbos darn near everyday - For sure every week. I spent 15 years at Paxton designing blowers and kits. Even at Paxton we offered Turbo kit support.
Bottom line - regardless of the engine if it starts to ping YOU GOTTA LIFT. My point as well as the others was simple...To window an engine as bad as he did he had to be on it for more than a simple millisecond. it took an effort :chainsaw:
But he knows that as well - no need to beat the dead horse. Now lets build a bigger better mousetrap
Weou09
Bham, Alabama
Ignorance is a state of being uninformed (lack of knowledge). The word ignorant is an adjective describing a person in the state of being unaware and is often used as an insult to describe individuals who deliberately ignore or disregard important information or facts.
My point is the person has to have the knowledge to ignore first. Not the case here lmao. More to the point has the guy found a replacement motor? lol ROUND 2? HAHAHAHAHAHA
interesting timing to return after 3 years of not being around.
Granatelli
I got a tickler saying I had not been around. Be be free, Its hard to run a business of this size and support all the boards. Plus as a business owner its seems like I have a huge target on my back a lot of the times.
Not sure about the timing thing - just happned across it.
weather man
Persistence Is A Bitch
MN
There are a lot of not so nice threads about Granatelli.
