Worst motor grenade ever seen!
mach828
Albuquerque, NM
Bad info.
Why? I used the BP modifier method when I tuned my HPX maf.
Isn't that the only way to get it to recognize more than 63lb/min of air flow? BP modifier and scaling the MAF or by scaling displacement, inj, etc.
lito
Caracas, Venezuela
The problem resides on assuming that some condition/limitation you may face is valid to everyone else, this is an S197 forum, what applied to your strategy on a EEC-V doesn't apply here, hence why I call it bad info.
Only 01-04 PCM's, when they switched the way airmass is handled in the strategy have that limitation AND even there, it depends on what you are doing to need it, because you changed the binary point you may not need to scale the tune at all, only when you reach the other hardcoded limitation you would do so, even depending on setup you may not even need it.
Diablosport information regarding MAFias is wrong and they should have explained it a little further (if want to check what applies here or not, here is a link: http://www.s197forum.com/forum/showpost.php?p=2007283&postcount=27)
Also, you can peg an HPX, BTDT, depends on mods and housing sizes, that is why the existence of the HPX-E is justified. BUT, people that read this, not every sensor is proper for everybody, having the correct sensor is really important here, big sensor on a big housing is a mistake too.
mach828
Albuquerque, NM
Cool! Thanks for taking the time to link that post and for the explanation. The amount of information available for understanding the different systems, software, and computers is very limited. And even for the available information its hard to determine who is a tooner vs a tuner. Only way for me to learn is through research, having ideas, and testing them. The only post 04 Ford pcm I've tuned was NA.
I realize its an s197 forum, hence why I joined. To learn about newer platforms. Once I've gained as much knowledge as I can from research I'll take some SCT classes to learn more.
Wes06
Love when lito drops knowledge bombs in threads
Kylar
CT, USA
Holy shit...this thread is awesome! ...lol
Definitely glad im being tuned by Lito
