MIR track rental set for Oct 12!
rayS197
virginia beach, virginia
Run AMSOIL SEVERE GEAR with Friction modifier
Cannot use that on a Trutrac differential. Regular Gear oil per Eaton, everyone on this forum and other forums . Eaton stated "DO NOT USE SYNTHETIC OIL". That statment came from two different Eaton employees I spoke with. There are no clutches in the Trutrac (gear driven) so no need for friction modifier.
retfr8flyr
The Old One
Providence Forge, VA
When I talked to Eaton about the lube for the Trutac they told me they didn't recommend synthetic because of the way synthetic oil sheared away from the metal, the regular gear oil worked better.
Earl
bullitt0175
bullitthead
Getting direct drills. Either Racestars or welds. Time to step my game up.
jodadejss06gt
TEAM DELETE SHIT
Severn MD
Too much game changing, I feel like I'm the only one that hasn't changed anything major. I returned the wastegate to the DP last night. Luckily I wasn't having major clearance issues like when I first put it on. I'm probably going to be down on power slightly, but hope that having the QTP it will negate it.
Something to get you boys pumped!
jodadejss06gt
TEAM DELETE SHIT
Severn MD
I uploaded it from my phone, it automatically did that I guess. So back on track....
Al, you going to spank Sean a new one or what. Ray, Jason, and I already have a grudge match. Big single with heads and cams vs small twins all on stock blocks???:evillaugh:
retfr8flyr
The Old One
Fixed! Earl when you going to turn that boost up:poke:???
I'll have the same boost for the rental but should be making more HP. I want that 10 second time slip, just like Greg wants his 9 second slip. Just remember, my sled weights 4070 lbs with me in it. Big heavy tires and wheels, heavy twin turbo setup and an old fat ass in the seat. :beerdrink:
Earl
jodadejss06gt
TEAM DELETE SHIT
Severn MD
Greg is running good power, Jeremy is closer to Greg than Earl. Earl is making a little more than we are and is more in our league with his weight. Sean and Al are close as well, but I'm not sure they will get one over on Greg.
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
Jason, Im thinking Greg vs Al vs Sean. Followed by Earl vs Jeremy.
We will see!
I think Al vs Sean would be the better run.
Jeremy needs some seat time to get the bugs out and re-learn his car/launch.
Greg Hazlett
Official Vendor
Chesapeake, VA
We have to see how Jeremy does with his new setup...he might have to have Mike dial in his tune at the track like he did with me and I suspect my tune will need tweaked again.
