UltraKla$$ic
PERENNIAL WAXXER
Louisiana
Your car redefines the stupid power of the F1A Procharger. Siiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiick!!!!!
crownaviation
http://www.tudyno.com/
Broke dafuk down
My piece of shit ipad wont show the video.. I hate "i" anything thank gawd for android
EDIT: thanks to my droid I just saw it.. nice!
05stroker
Never enough power guy!
Bullard Tx.
Pulled the plugs today after the dyno earlier this week and two data logging passes at the track yesterday. Happy to say the plugs look great. Time to dial it in and get back to some fast times!
toorbeenee
turbine lunatic
dubai
Awesome job on the engine.
When you see spark plugs like those you know have a great tuner.
Well done billy
05stroker
Bullard Tx.
I guess its time to update this thread. This last year I was able to get the car to a best of 9.38 at 146 mph with a 1.39 60ft. Then ran the gas tank low on fuel and leaned out the motor thus melting pistons yet again. Then after reassembling the motor in a couple weeks, I somehow managed to get a small ss bolt in the intake system post IC and destroyed the bank 2 pistons. See here if you haven't already.
http://www.s197forum.com/forum/showthread.php?t=108563
So while the motor is out I decided to remove the N2O kit I have never used and go with a high compression build with a set of Manley flattop pistons at 11.6:1 and still run my 23 or so psi. on E85.
I also decided to upgrade the rear main (thanks againstallodds) to a solid unit by using a second full main bearing and cutting a groove in the block. I will update with installed pics when they go in.
I also will be o ringing the block with this tool from Isky Racing. Thanks to againstallodds again for the info he provided here.
Next was to make the heads breath better. I was very nervous about cutting into the heads but am very happy with the results. The are much larger then before and will hit a flow bench this week to be tested. No matter what they flow on the bench they will flow better under 20+ psi. Here is more info on the heads.
http://www.s197forum.com/forum/showthread.php?t=108899
Now to make sure to never be fooled by my gas gauge again. I picked this cell up from a member here. it holds 12 gal. and is designed to use the stock style pump like the Fore billet unit I have now. I just need to do some testing to see if the sending unit on the passengers side of the factory tank needs to be installed in the cell to keep the use of the fuel gauge in the dash working correctly. I am installing the tank with the fuel pump at the rear and may move the filler hole to the rear if the sending unit needs to be used.
Looking for some 8.50s this next year if all goes well. That's it for now, I will update more as I go.
Mystickeith50
South Jersey
Mother of god....is there anything u can't do? I was pissed off as a mofo when I had to rip off my front bumper to fix my intercooler pump this past weekend.....I'm lazy, ur awesome.
psfracer
billy badass
Valencia, CA
If he is lucky he might be able to hang with a 5.0, if its stock. We already covered this earlier this year.
Seriously though this should be pretty impressive when it goes back together. The heads turned out pretty good. With that compression on E85 @ 23 psi, this should make a lot of power for sure.
ILW84U
Edmonton, Alberta
These current mods are looking great. I think that shooting for 8:50's is going to take the "street car" label away.
05stroker
Bullard Tx.
I thought you were already had o rings. How does that tool work?
No I have thought about it but haven't done it till now. That tool sits in the cylinder bore and you spin it while applying pressure down and the blade cut to the depth you have set. Then you install the ss wire and copper gaskets made for the o ring setup.
crownaviation
Broke dafuk down
Bad ass!
I just killed my tranny again last night so thinking of just taking the motor down and doing some more head work and the o-rings. I am very scared of the boost and nitrous. Just a matter of time imo before head gaskets fail.
Love that dads tank btw.. they do some really amazing work. I think you can figure out that second sending unit. Problem is it controls the first half of the gauge
