lethe
V4g!n@ #er
Looking Good!
We will see, I have always been a fan of the OEM head gaskets. They say when you o-ring and use copper it is the best possible seal you can have. I guess I will find out.
I wouldn't use it with OEM gaskets, but definately with the copper.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Ready to pull my heads and get started soon.. Overall what are your impressios of the o-ring kit and final finish?
When I put my heads on I brushed both sides of the gaskets with permatex super 300. That will give it a better seal around thd water jackets.
Its messy but it works.
Why not sir? I have been using oem in my car for years now never had a problem. Went all the way to 22 psi. Could go more but didn't want to
I thought about that too. I actually have some in the garage. I feel like the Permitex would seal better though. I may test both on some sheet metal and see which on feels stronger.I've read of people using the spray copper too. I should of done it with my big bore as the Cometic gaskets didn't have sealant. So far so good without it though.
We use the copper spay on all the gaskets even on diesel engines with turbochargers.
I think the best thing is to have flat surfaces. In my case the gasket is mls which will form to a degree. I'd imagine that your copper is also going to deform with any minute surface imperfections.
My block was freshly decked to 28 or 38 ra iirc. It was within the Ford spec. I also checked the heads and they were under .001" everywhere. I've used heads with .0015" in a few spots and still not had problems up to 19psi.
I think I will use the Permatex super 300. Its seems the better choice.ive used the spray many times, no issues, but also dont know if it really helped anything,lol
You need to call Scott Rod Fab. And thanks!Looks good Billy. Cant wait until you come do mine! Lol
Im trying to decide if I want to pull the dash to remove the heater/A/C unit. I really need to anyhow to install the new carpet correctly, but man it will be a job with all my aftermarket parts and wiring in there. I may just cut the carpet into the sides and wait to remove the HVAC unit when I do my 12pt later this year.
Just a word to the wise, unless you are building a 100% race car leave the heater/defroster in it. There is nothing worse than being out on a nice cool fall night and not being able to see.![]()
