Sorry about your bank account. Another example of why I refuse to use a debit card. By sticking with credit cards only the bank's money is at risk when shopping online. My checking account info isn't shared with anybody.
Just an FYI, its not a bad thing to have a credit card. I actually put all my purchases every month on it and pay it off at the end of each month. I get air miles and my bank card info isn't all over the place. Id have to go to the bank frequently or carry a bunch of cash around if I payed that way. I refuse to do that because If were to ever get robbed they'd only get 40 bucks. I'll get the credit card stuff back.
Good luck with it.
Also an FYI, TitanMotorsports on Ebay seems to have the cheapest price on ARP bolts, but I had to wait about 2 weeks to get them. I got head and main bolts. I'd call them first to see if you can get them quicker if you are going that way.
Is that going to clear the motor mount? I couldnt get a union, T, and stock sensor to clear the driver mount.
May anyone know the part number to this heater core nipple? Or what size O rings it needs, since I have an entire kit.
Sent from my iPhone using Tapatalk![]()
You can buy a plug kit from frpp that has it included for $12. I used orings from a kit on one of my builds. It's not too hard to figure out which ones to use. The ones I ended up with fit perfect inside diameter but were just a little bit to big on the od. A little vasoline and everything was fine.
Alright so after learning that the 3v and gt500 oil pumps are the same besides the pressure relief spring, I am going to pick one up at local auto parts store, melling m340 and reuse the pick-up tube I already have.
Some Q's, has anyone used the fel-pro rear main seal or stuck with the oem? I know some have had leaking issues or wouldn't go on. Just wanted to know before I either make a trip to Ford or get a fel-pro at the parts store. Also, any idea what torque value the boss 302 rod bolts are suppose to be?? I can't seem to find it anywhere.
Don't use the fel pro. They supply a National brand. I've had issues the only time I used one. Spend the money for oem Motorcraft.
IIRC the bolts are 55 ft lbs. It's posted in one of my theads by 19COBRA93.
