MilehighGS
Replaced rear sway bar bushings with Energy suspension ones...........that job sucked!!!
Sent from my SM-G975U using Tapatalk
It's like taking a trip to the dentist.
Started test fitting tonight. Square or staggered? Ran into issues with square. I will need a spacer for gt500 calipers. Also, center cap won't fit because of bearing grease cap. Then with a spacer I am afraid I will need to run too much camber to look flush. Lastly, I want same size tires, but I don't want smaller than 295/30/20 out back.. I don't think front will run it without ghetto trimming..
Those will look classy when it’s all said and done, make sure to post finished pictures! Also, red truck out in the street looks like fun too!
What is the offset on those?
I thought they were 40mm which should fit. Might only need a small 5mm or so spacer.
As far as the grease cap, u can usually tap it down with a small hammer to flatten it out, might give you enough clearance to put the center cap on.
This statement could really be taken the wrong wayFeels good? glad ya got it in!
that's what you said last night wasn't it?Feels good? glad ya got it in!
Guess I left my self open for that one... wait..This statement could really be taken the wrong way
Yeah clutch feels great and trans shifting like butter nowFeels good? glad ya got it in!
