2011 5.0 - Power loss, gas smell in cabin, and many other problems
JGas
North Alabama
I have owned my 2011 Mustang for about 2 years and have had numerous problems with it, a few months after i got it i noticed a power loss that was significant and got the compression checked and was told that compression is lost once it gets to operating temp and was never able to find a fix, engine blew up 6 months later and now my second engine is having the same exact issue, along with a very very strong raw gas smell in the cabin when sitting still. car is completely stock besides tune and gutted cats done by previous owner, thanks for all help in advance.
07gts197
Naples, Fl
Was the tune on it before the first motor blew up? What injectors do you have?
Dino Dino Bambino
I have a red car
Cyprus
You might want to remove the rear seat bottom and see if there's any fuel leak around the gauge sending unit/fuel pump assembly.
I'd also suggest having cats installed and getting the ECU reflashed to stock before you lose the second engine.
JEWC_Motorsports
S197 Junkie
Whose tune is it? Lets start there. Also checking under the rear seat for the gas leak would be a good place to start.
JGas
North Alabama
Stock injectors, tune was on car for about a year before the engine went.
JGas
North Alabama
Was done by previous owner but as far as I know it's just a baseline 87 octane tune from Bama
tjm73
of Omicron Persei 8
Rush, NY
Some same bama (bam-ah). Some say bama (bom-ah). I say junka (junk-ah).
JGas
North Alabama
A cel will come on with gutted cats and stock tune. google bama number 8 issues.
a CEL is better than letting this bama tune continue to damage correct? I found a thread about the bama cylinder 8 issues and a guy was saying that he also had power loss similar to the way I am as well as experiencing a heavy amount of white smoke when at idle (which I forgot to mention in the original post)
yeah... starting to see why I got the deal I got on the car, previous owner must've knew what was coming and decided to put it in someone else's lap
tjm73
of Omicron Persei 8
Rush, NY
You have power loss and white smoke?m Are you losing coolant as well? I forget what exactly happens when #8 fails.
JGas
North Alabama
just reflashed to stock. going to be putting some stock cats on this weekend and hoping atleast some of my issues are resolved
Dino Dino Bambino
I have a red car
Cyprus
White smoke is usually coolant and that would suggest a blown head gasket.
@JGas, are you getting any coolant loss?
The no.8 cylinder on the Gen 1 Coyote suffers from poor coolant flow in the cylinder head so if that cylinder detonates, the exhaust valves get too hot and cause premature guide wear. It often presents with increased oil consumption and a misfire from an oil contaminated spark plug. The engine may also produce a ticking sound due to the exhaust valve stems rattling in the guides. If it isn't fixed, a valve may break and cause catastrophic engine damage.
JGas
North Alabama
If you have white smoke coming out of the exhaust, you have more problems than just the tune.
well I guess applying the stock tune making it stop is a coincidence
No coolant loss was found I checked for that this past weekend and as far as a ticking noise would go one is starting to develop in the front passenger side but is only noticable when between 2500-3000 RPM in 2nd or 3rd gear
tjm73
of Omicron Persei 8
Rush, NY
Man you better get this car checked over before you have another engine failure.
MrAwesome987
Upstate SC
I'd certainly say so as well. Someone is going to have to explain that to us both. White smoke implies a mechanical issue with water being in the wrong place. A tune isn't going to fix that. It might cause it, but once damage is done, I don't see how its going to fix it.
Are you sure the smoke is white? Like really white?
Edited: fixed typo
JGas
North Alabama
am going to after the holidays. reflashing to stock did resolve my loss of power from what my butt Dyno says, as well as the smoke at idle
Edited: fixed typo
vape cloud white.
