Getting closer and closer to getting this build done. Engine is built, t56 magnum is here and much more.
I want to know for those who have done it, your thoughts and opinions on some built rear ends.
I hear true Trac is the way to go, with the upgraded axles and c clip eliminators.
My t56 magnum has the 2.97 first. I'd like a decent cruising rpm while on the highway when in 6th. Granted, the gearing in the trans will already help with this, but what should I expect with other ratios? I'm used to the 3.55 with the stock 3650.
Thanks yall.
Also, I'd *prefer* an entire built assembly , as cost isn't a factor. If there is not a good option out there, I'll settle for a build kit.
I hear the stock diffentials from 07-09 gt500s hold up very very well, too so I'm a bit torn.
Sent from my SM-N986U using Tapatalk
Thanks yall.
