No not really.. V6 chassis is quite competent for daily driving and can be upgraded gradually IF and WHEN you want. Brakes are quite good for daily driving, suspension is more than acceptable for daily commuting, are you after absolute performance? Or a budget performer which is what the Mustang WAS and IS truly about. It IS NOT EXPENSIVE to mod a Mustang or go Coyote. That is a BS MYTH from uninformed individuals.
I'm still amazed that you found a Coyote long block for only $250. That's normally the most expensive item in the swap. That said, used Coyote engines have become dime a dozen and other salvage parts are also easier to find used, so a swap can cost a lot less nowadays than it would have, say, five years ago.
Do post a video of your engine running after you fire it up, and update your parts list. It'll be a good reference for anyone else considering a Coyote swap.
