how would you breakin a new ShrtBlock
007SHELBYGT
I have a build 3v short block fully forged stg2 ported heads and comp spr cams 127550 with a votech V3 ..would you put it in and drive easy for 500 miles or so ..or warm it up drop the oil ..put new oil and dyno it !!!!
JeremyH
3V Fuel Guru
Virginia Beach
Everyone has opinoins on how to do it, heres the common way.
The most important part is to make sure everthings coated with oil prior to start up.
Fill with some conventional oil. Pressurize the oil or pull the fuel pump fuse and crank the car a couple times to get oil everywhere. Start it up let it get up to full temp drive it easy and give it some healthly revs. Change the oil/filter to the good stuff of your choice.
Let her rip on the dyno.
graygt07
peoria il.
i was told to start it let it idle 10 minutes then run it 1000 mikes with a high zinc oil. vr1. then its broke in.........but after 1700 miles and a brenspeed tune my jdm shortblock has a hole in the piston so maybe you should not follow my lead...
You only have one chance to break it in. Like lightspeed said there are different ideas about it.
I can tell you how I did mine. Start up and vary rpms for the first 20 minutes, drove for about 10 minutes and changed the oil. Drove for another 350 miles progressively putting more load on it. Put it on the dyno at 350 miles and I believe that was the best thing to do. The catch can suddenly had less blow by after that tuning session. I believe the dyno pretty much finished the break in. I still ran conventional oil for about the first 1100 miles.
If I build another motor it's going to the dyno right away to be broken in.
19COBRA93
Ford Racing
Clinton, Ut
Asking the right way to break in an engine is just like asking what the right way to choke your chicken is... Everyone does it differently.
And really, there isn't one answer. It depends on what rings you have and what oil is in it, and a few other things.
onequicktang
Orion, MI
brenspeed told me heat cycles are the main thing not so much milage. I did about 20 heat cycles and about 400 miles then on to the dyno.
05yellowgt
Dayton, OH
My engine was primed, started, pulled onto the dyno and did about 15 n/a dyno pulls to see what it would do (316/353) then the blower went on and dyno tuning commenced with the Procharger. Oil was changed then and then at the end of the season. Been running strong since. I switched from dyno to synthetic oil at that point as well.
Fallenauthority
La Plata, MD
LMAO E-thug! You're such a hardass, go you!
SEARCH button, motherfucker!!!!!!
MUST HAVE LITTLE PEE-PEE SYNDROME>>> If i knew were to locate you i give you some 6'8 295lb beatin MOTHERFUCKER!!! To everyone else Thanks for the input !!!
Sent from my Droid using Tapatalk
302
Atlanta GA
Mechanically, if its going to break its going in 30 seconds or less....
US-1
Banned
The ShadowLands
I'm positively terrified. :LMAO:
Be careful of what you seek.
Read these threads..........
Then look around, familiarize yourself with the landscape, and try to figure out the "Who's Who" before regurgitating such drivel on this site.
SilentScope
Chemist by profession
South Florida
alright lets not take this to the pitstop because i would like to see everyones very different opinions on what they think is the best way to break it in.... and then i want to see who's engine lasts the longest!!!! haha
Tre06GTP1SC
South Texas Death Ride
El Paso, Tx
Like SD politely suggested. Use the search. There are a lot of info on here about engine break in.
