2008 ROUSH Stage 3 Build...Take III
AutoXRacer
Florida
Setting PSI on a PD blower is easy/simple. Just choose the pulleys accordingly and you're set.
Its just a bummer to have to limit the PSI to 10-12 PSI for pump gas.
Having a 1000HP motor to only limit it to 600HP. sigh. lol
(Yes, I complain a lot about this...I just had my hopes up) I need a bigger motor... Like a 6.0L. lol LS1 anyone??? LOL
eighty6gt
If I wind up keeping my '08 through the end of being able to drive our own cars, I'd like to throw a 427 Windsor in it.
AutoXRacer
Florida
So I ordered this tool from Innovators West and I am very disappointed to say that its useless for removing the balancer.
I had to use my cheap $15 pulley remover from AutoZone to remove it.
The damn tool didn't even come with the correct bolts to screw into the balancer. All its good for is for installation. What the??? $125 really??
eighty6gt
Ohhhhh you wanted the removal/install tool! I thought you just wanted the INSTALL tool! The remove/install tool is $375. No returns on tools, store credit only!
AutoXRacer
Florida
Oh snap!!
I just called Innovators West and they just told me their tool is only for installation on mod motors. sigh
So good thing I had a cheap $15 remover... lol
$125 hurts just for an installer...which I now realize my balancer may not have been fully seated on the last motor build. Good thing it only ran for 1,000 miles. lol
It does beat $375 though...
One weird this they told me was that applying gasket maker on the keyways is not required... They did emphasize on the use of anti-seize on the crank snout and the balancer. Thats when I asked about the gasket maker on the keyways. The anti-seize will definitely interfere with the gasket maker.
Any thoughts? I guess you could always make sure your washer has a coat of gasket maker and use that as a seal for any potential oil seepage from the balancer/crank.
eighty6gt
I like the idea of a little anti seize. I would also appreciate not having to futz around with the rtv or gasket maker.
You could anti seize most of the thing, then gasket make the rest.
05stroker
Never enough power guy!
Bullard Tx.
I use anti seize on the snout and keyways and then use RTV on the back of the ARP balancer bolt nut to seal.
AutoXRacer
Florida
I used the tool tonight, again useless until you are 3/4 onto the crank. The threaded adapter part does not reach the crank until the balancer is 3/4 of the way on.
What the fudge!!??
Going to call tomorrow and see if they sold me the wrong adapter. Sigh
AutoXRacer
Florida
Just spoke with Innovators West... I got the wrong adapter. I need the GT500 "extended" adapter. sigh
Balancer is installed!! I'm going to remove the crank sensor and slide in my borescope camera and make sure its fully seated against the timing gears and crank sensor wheel before I lock and load it with the installation bolt.
Boy, using that anti-seize stuff made it slide onto the crank like butter!!
I guess lube is a good thing... LOL
AutoXRacer
Florida
One thing I am super excited and ecstatic about is the new VMP Tuning GenII blower!! You can R&R the plugs without removing the throttle body!!
Something us ROUSH blower guys absolutely find frustrating!!
Plug #8
I did have to use a swivel adapter though.
Plug #7
Installed the drive system... 3.0" upper pulley and 6.55". I previously had the 3.0" and a 7.40" that made 14 PSI. Lets see how much the slower setup makes.
Here is the Venom Cooler setup; hose and fittings:
You splice these into your coolant hoses (supercharger coolant).
S
santi_bh88
Guest
Gerald paint the alternator braket in black to look better! :) remember me what you can see in that gauge?
