What is the width of the exhaust valve clearance? and your depth is .075 from the top of the piston? What is the typical dimension for a 3v piston?
Is that pan cast aluminium?
If so, be careful of running any hard objects over, they can crack vs dent, and drop all your oil. Cost me a motor on a VW 12 years ago. Thanks to the wife.
It also has a bung on the side just in case I ever need to return oil to the pan from somewhere else.
Hard asa motherfucker....ham.
Beginning goal is 400/400 on 92 pump gas and stock like driveability. The goal for E85 is 420/420.
I've done just about all the work I can in preparation for this project. The only thing left is waiting a few more days. Sounds easy but I've already been waiting two weeks longer than I had thought it would be. All I can do is talk about it.
What is your goal as far as numbers wise?
