If I remember correctly Roush did some of the CNC work for FRPP for a quick minute but Livernois has been doing the job for quite sometime now.
Read through the thread. Im pretty sure it has been posted that Livernois has used the bronze guides in their stage II heads.
Tre, glad to see that things are working in your favor here! Hopefully you will get everything up and running shortly.
The only two heads that Ford Racing makes are the ported heads and the stage 3, the stage 3 have bronze guides. I wasn't talking about the Livernois heads just the Ford Racing ones lol
That's good to hear Tre. Like I said before, Mike seems to be one of the only employees in that shop that still have an understanding of customer service.
With that said...any word on those replacement o-rings Mike?
Damn, pics look very similair to my passenger side head failure in post #1. I was told it was a valve guide issue by Livernois, they replaced the head. They got my heads and cams this past tuesday. I expect to hear from Mike with their plan Monday or Tuesday.
Did you have any issues getting them fixed?
are these the big valve FRPP heads or factory ported? i have the factory ported FRPP heads, they are no longer listed in the FRPP catalog and i have been wondering about them.
i know FRPP had a few designations for the HP cylinder heads for the 3V's. they had the factory heads with ported intake/exhaust ports in 12mm plugs, they have the same as before with 14mm plugs and then the oversized valve heads with 14mm plugs?
if you have the factory port valves can you tell me the casting numbers on the front of the heads? i wanna cross check when mine were made as im afraid im going to end up like one of these one day. although i have almost 30k on mine and no problems so far?!?
so....what's the consensus here?
are bronze guides in general a bad idea for 3v heads?
have we heard any horror stories about bronze guides from other speed shops like modular head shop, or bbr, fox lake or anyone else?
is it only that livernois seems to be affected because the shear volume of heads they turn out?
In talking to others here and testing the heads with a stock manifold, I have a feeling this is due to the tolerance in the aftermarket supercharger manifold. You have to understand these are aftermarket parts and not all made to OEM spec or tolerances. With a stock manifold, it's very close but there are no issues. The heads are made large for a reason.. for max performance.
Man now you guys have me worried about the heads sealing with my C & L intake manifold.....FUckers!
Although I believe I saw a test that C&L did with the Livernois Stage II's and there were no reported issues. Still, twice bitten, now shy.
We've used the C&L and FRPP manifold with the stage 2&3 heads and have never had issues with them.
-Rick
-Rick
How about answering my questions? Or are those too hard?
It would be nice to see pics of the cam tower misalignment in action with either pics or better yet, a video. This seems to be what Livernois is pointing the finger at.
Yeah, I agree, considering the first failure I had this was not the explanation given. (although the symptoms were similar) Now its something different and they admit fault yet they try and backhandly throw it on the installer. Interesting indeed. But I will still give Livernois credit for replacing the heads. Thank God its not a BBR Hellion system im having trouble with.
Oh and Mike and you say you have nothing to do with the cylinder head department?
http://www.linkedin.com/in/mikeschropp
