Wastegate vacuum line
Fantas
Smokn, if you need any help with the install feel free to get ahold of me. I finished my install a week ago or so. What do you plan on doing on the fuel side of the house?
JoshK
Modder AKA Fuel
Nebraska
I used a heavy 1/4" ID fuel line for my WG/BOV lines. The wall of the hose is reinforced and a little thicker than normal hose, so it should resist flex/expansion a little better than normal vacuum lines.
Same line I am using as well. :thumb:
S197_smokn
Columbia, MO
Thanks bud I will prob hit you up, bought Jeremy's 405 kit 39lb injectors. Wanting to make around 470 to 480hp. I pretty much have everything installed besides the turbo. The on3 turbo was shot didn't notice untill I had everything bolted up
Fantas
Fuel, what clamps did you say you were using for your oil relo?
Fantas
It arrived messed up? Did you try to clear it up or did you just order a replacement from comp? Did you go oilless?
JoshK
Modder AKA Fuel
Nebraska
My clamps are basically the same diameter as the on3/S&H clamps, just wider and heavier. You can find them at any auto parts store.
S197_smokn
Columbia, MO
Well I bought the kit used and the member that sold it to me had no idea and gave me some money back. I knew Jeremy was selling the comp turbo got a polished one but not the oilless didn't have the funds and just dropped 13 bills on wheels and tires. Wasn't expecting to buy a turbo
Fantas
The On3 kit just came with a Jegs oil-relo kit, all it had were regular worm gear clamps. I'll go see what I can scrounge up.
Full_Tilt
You guys are cracking me up with all this stuff about heavy duty hose and clamps.
I've had regular silicone vacuum line to well over 20 psi with no clamps. Just barb fittings.
They won't blow off. Its not that much pressure and the surface area is tiny.
They are talking about the oil fitler relocation line clamps.
I run silicone vac hose as well no issue at 16psi, I did add a small ziptie over all the barbs for good measure.
Full_Tilt
Oh my bad :dunce:
I was about to say, its good to be safe but thats some crazy overkill, haha
Fantas
Oh my bad :dunce:
Fuel said that he has had (one or two, can't remember) instances in which his oil lines came off the barb fittings.
ctt326
Brenspeed Hater
Fort Wayne, IN
Mine came off the barb twice before I wised up and purchased some stainless hoses and fittings instead of those POS worm clamps.
what hose and fitting did you go with. Mine came off while racing before... scariest night of my life
