whoaaa EBAY Alert Brenspeed Blower Cams CHEAP
muztangman93
Indiana
I just hope they are the cams listed and not the stock ones tossed back in the box. Told him to check before he shipped em
GT Speeder13
Clermont, FL
HAHA, I was in a bidding war when he bought those from brenspeed 6 months ago! He won obviously and for a lot less than what he sold them for. Wish they were mine!
ROUSH1711
UNDER CONSTRUCTION
DE
He got them cheaper? wow!
muztangman93
Indiana
Brenspeed had them listed on ebay. Just curious what did they bring the first time.
gtcs07
Im just kinda here
New Jersey
lets see if the are nsr pull the valve covers which are 8 mm then get yourself a timing chain wedge and spring compressor compress the springs enough to pull the followers wedge the chain un bolt the phaser unbolt the cam caps pull the cams and reverse. phasers are 15mm and cam caps are 10mm
muztangman93
Indiana
So I only need to put the cams in dont need anything mechanical for the install like springs or anything. Just a direct replacement uses stock springs and phasers
gtcs07
Im just kinda here
New Jersey
as long as it is a NSR cam then all you need to replace are the cams. your obviously better off doing springs and retainers but its not mandatory if they are nsr.
b00stedgt
New York
Let me know if you need to rent a timing chain wedge and spring compressor
muztangman93
Indiana
Was gonna make a timing chain wedge looked pretty simple to do. What you want for yours.
StangPower05
"Pony Up"
NY
muztangman93
Indiana
Got the cams they are used. They have marks all the way around the all the lobes where you can see the use. Not alot of use but they are used. I contacted him to return them.
muztangman93
Indiana
