Looking good
Looks great as always.
How "sealed" is the trunk? Now keep in mind I come from a forum of motorsports where it isn't a question of if your going to crash, but how often. And in a lot of cases BIG. But that fuel system "inside" the car scares the crap out of me.
Not knocking your work. Fire inside of a car is something that is way down my list of things to do. And I think crashing motorcycles at 160+mph is not that big of a deal.
Did you seal up all the holes in the rear deck too?It will be as sealed as well as .040 aluminum and fire caulking can get you. The fire caulk I will use is the same used in commercial building to prevent flames from spreading from floor to floor. The weak link is the wiring harnesses that go though each side. Other then that, I will be sealed.
That sucks. That is actually my worst fear with my car. Getting burned up would suck. Loosing the entire car would suck a lot too. I've got 3 halon extinguishers in the car. I need to get my crap together and run a real fire suppression system though. They aren't that expensive really.I have friend here that lost his 9 second GT500 last year due to the fuel pump ring not being seated properly and leaked on the exhaust and caused him to loose the car and get a pretty good burn on his leg. He is coming back with a very nice large turbo build with a glide and a fire suppression system. I don't want to do that yet, but his accident made me think about it for sure!
No F&*%ING thank you! I'll pass! I've slid down the track on my face at 150+mph more then a few times. I'd much rather do that.He went though the traps at 150+ on fire!
Also remember, with a stock car, the only thing between you and the fuel system is a piece of plastic and a foam rear seat!
I went completely bezerko overkill with my bulkhead and used .125 sheet, but I'm also using it to stiffen the chassis up for the rear suspension. Different application, different intended use. I think I used .35 or .40 on the rear deck and for the holes to the sides of the pass through.
I caulk'd everything up too.
Not much to do about the wiring, I agree. I just made the holes as small as possible and used big grommets.
Sounds like you have it covered, it's just scary shit.
Yeah, but they aren't pumping 1000+hp worth of fuel either.![]()
Seen a guy this weekend at nmra get airlifted after hitting the wall at 193mph.....
One more reason the inertia switch still controls the relay for the fuel pumps in my car. It wont help in a spill, but at least it will shut the pumps off.
Mine is wired the same.Mine is still hooked into my pumps too (I'm using it to break the trigger wire connection, not the grounds). No way I want to turn the car into a flame thrower.
I cant wait to run this thing around on the streets with it looking like the pic in my sig! Frigin 9.00 car on 20s! lol![]()
Yeah, if I didn't know who you were I would take the bait.
You would slaughter me from a dig. A 50-60 roll would be fun though.![]()
I don't mind roll racing, I will take that when we finally meet up. In Mexico, the high HP is a blast!
Most likely something I will do when I do the 12 pt cage.Hey Billy.. you need to do a few practice evacuations from your car every so often. Not a bad idea to throw in a few get out from the passenger side trials also. Fire suit is nice but that is not what kills most guys. smoke does.
Fire suppression is a must on something like you have. I am not taking my car down the track till mine is installed and practiced a bit. As Jason mentioned.. fire is way down on my list too and have seen too many cars built by meticulous people go up in flames. Just a risk we take at this level
Fire suppression is probably not going to extinguish a fire either. only likely going to buy you enough time to get out.
This is no shit..
This is no shit..
