FRPP 3V supercharger shortblock build
Liftedbronco
Shredder
Harrington Park, NJ
Ok im back on it. Hey, when im ready to put the intake manifold back on for the supercharger, do i use stock intake gaskets? Or are there special ones for the whipple?
Stock as long as they are for an intake manifold with seperate imrc plates (2005-2009).
The Whipple instructions should tell you to reuse your stock ones.
Liftedbronco
Shredder
Harrington Park, NJ
Thanks, thats what I thought. I just didnt feel like breakin out the whipple manual yet.
Hopefully my chains come today so I can get it all strung together and get the timing cover on. "baby steps"
Liftedbronco
Shredder
Harrington Park, NJ
nothing last nite other than figuring out i lost the bolts for the timing chain guides. Since my last pic ive slid the timing gears on the crank. Looks to me like the woodruff key on the crank is not a key at all, but actually machined into the shaft, so i suppose i dont need to RTV that. So tonite if the chains and now bolts come, I will get the thing chained, timed and get the timing cover on.
Based on tmcolegr's build thread I think at that time i should be prelubing the engine so its off to lowes to get a sprayer. I cant believe they sell prelubers for $150 and its the same thing!
Liftedbronco
Shredder
Harrington Park, NJ
funny question - how can i tell if i have lockouts installed on the cams? got these heads secondhand so i want to verify everything. also, i read that with lockouts you can lock full advanced or full retard. how can i tell that? because im sure my tuner would want to know.
You would never want to lock full retard and nobody would install them that way on purpose. The only way I can think of to verify lockouts are installed off hand is to take the back phaser plate off. I'm not having a way to check with everything hooked up come to mind other than datalogging cam postition but that would be hard to do with the motor not running, lol.
Liftedbronco
Shredder
Harrington Park, NJ
well you solved one problem for sure. assume its locked full advance. once its running on a startup tune, im sure then my tuner can figure that out.
Thanks!
btw update - chains and bolts for guides are in my posession and will go on 2nite. if i do real good ill get the timing cover on and the oil pan with the livernois scraper. Really really good would be valve covers and we could have this thing sealed up 2nite!
Liftedbronco
Shredder
Harrington Park, NJ
Gonna get whiplash this is coming so fast.
chains on. (cool shot of my it looks messier than it is garage)
tensioners and guides on
front cover laid on. didnt have the right rtv so i have to wait till 2nite to finish that.
Liftedbronco
Shredder
Harrington Park, NJ
it was such a bear figuring out which bolts go where on the timing cover. the shop manual gives you bolt dimensions with numbers for the torque sequence. i had to measure and categorize them by number (position).
HxCGuitars
IL
Well hey, that's alright! Can't wait to see it progress. Contemplating doing a similar build myself hopefully a few years after I get out of college. Just a freshman now, so it'll be a while, but hey :thumb:
Liftedbronco
Shredder
Harrington Park, NJ
Crank pulley on. Put some rtv on the woodruff key to seal any oil weeping. Crankshaft seal was installed on the timing cover before installing on the motor.
Last nite (no pics) I put on the fr500s oil line/radiator hose thing that replaces the part that the original oil filter goes. Going to do the remote oil filter. Also I put on the motor mount pedistals.
