Ok so I have been distracted by a lot of things lately -- buying new house, got into road biking (in addition to mountain biking which I have always done), extra busy with work, etc, etc.
But its finally starting to come together.
First--Camshaft will be the following:
288 degrees duration
@.50 intake, 306 degrees duration
@.050 exhaust.
.945 lift intake / .925 lift exhaust
Roller Lifters will be the .945 diameter, bushed with a keyway vs the usual pair of roller lifters that are connected via bar to prevent rotation in the lifter bore. This is so I can run 7/16ths pushrods, .160 wall, while maintaining clearance around the intake ports of the heads.
Valve springs--serious pieces with 400lbs on the seat and over 1,100 lbs open. No way I am getting any valve float to the expected rpm peak of 8200 rpm. Already titanium retainers and valves, but even the titanium retainers have that groove to reduce weight. Serious pieces:
Oliver rods with 7/16 rod bolts, f'n huge, for it to be bullet proof.
Diamond pistons with deck height to allow for 16+ to 1 compression.
Should be ready soon, hopefully on the dyno in July.
