Department Of Boost
Alpha Geek
- Joined
- May 26, 2010
- Posts
- 8,808
- Reaction score
- 31
YesWill a 1-piece DS w/ a c/v joint work well enough?
CorrectIt still should be better to have a correct pinion angle(via UCA) even w/ the stock DS after a 1.5" drop, right?
If you can put a DS in you can mess with the motor/trans mounts. They are easy.I'm don't have access to a garage to start messing w/ motor and trans mounts, seems easier just to upgrade(or downgrade the DS).
Hard to say, vibrations are no good for the trans/rear end.Will it hurt anything to try driving w/ the current dynotech DS, or should I plan on doing everything in one shot?
